1 - 11 of 11 Posts
Ok i am swapping in a carbed 350 for the 2.8. Its a 4x4 so i would need a different oil pan. I think i should be able to cut the bottom part off of a 4x4 4.3 and weld it to the bottom of the regular 350 pan. I would weld in a extension but my dipstick is on the drivers side (72' 350).Does any one else think this idea will work. I dont wanna buy a pan for $250 and i picked up a 4.3 4x4 pan for 30 bucks.
thats what alot of people do just make sure the welds are good and you should be good to go. remember to alwayse cut short! :D
Yes it looks like it would work
Ask your friends if they have access to a TIG welder ,it makes nice beads.Make sure to use the right length oil pump pick-up.DO you have your exhaust yet?
ya for your oil picup you need to use the one from a 4x4 4.3 it should fit without a problem
Yeah i got the right pickup but no exhaust yet. Just finished building up the motor and getting the engine compartment ready for the v-8.
but my dipstick is on the drivers side not the passengers.
Yeah
There cheaper and give you lots of room on the sterring shaft.You probally know which ones to use?They work fine for a moderate hp engine.Good luck on the change over and feel free to ask any questions.
1 - 11 of 11 Posts
