Changed the oil in my 2003 S10 crew cab today, with mobile one synthetic. The 4.3 oil cap. is 4.5 qts. and I was thinking the jug I had was 4 quarts, it was 5 qts putting it 1/2 qt over. Yes, every manual says don't over fill but I've read that on most engines you can go a quart over with no problem. I don't see how a half quart could possibly cause a foaming problem. Anyone else do this and just leave it in?
94 4x4,01 Blazer
Your oil pan will hold more than 5 qts without any issue.The problem that arises from overfilling is at a high enough amount, the oil will come in contact with the crank , causing said foaming as it gets continually stirred by the crank. Plus that also adds a boatload of drag to your moving parts,robbing you of power and milage.
Just to update, brought the engine up to operating temperature at 50 mph and my gauge is reading 45 psi. It was 10-30 Mobil 1 but truck has 160 + thousand miles. I don't put 10,000 miles on this truck so ought to be good for the year.
