finally runs!
i want my tires to stick out a little on my 96 Silverado 4x4. its stock for now im not putting to big of a lift. just enough to look different. but i dont know the measurements. looking for the backspacing i could use to clear tires with out trimming. i dont know the stock bs any ideas would help thanks
most lift it will get will be 2 inch
Premium Member
33"s should fit pretty well. You may or may not need the leveling kit to clear the tires. I'd look for a 16x8 with a 0 or -6mm offset. This should put your wheels where you want them.
