Alrighty then. I’m going to try to give as much information as possible.
2000 4.3 Extended Cab here
I have a lot of experience installing aftermarket stereos, lighting, audio systems etc. I wire everything as professionally as possible blah blah blah.
Easy peezy, just installing some led strips today. Popped off the S10’s flimsy trim and removed the stereo.
NOW.
I decided I didn’t like the lame USB connector that it came with since I like everything hidden, and cut it off. Stripped the two wires. I spliced them into the illumination and ground wires on the stereos harness following the “proper” wiring diagram and I have literally done this for every car and I’ve owned.
I turned the truck on.
No lights.
No gauge/cluster lights, stereo didn’t light up, and no LED’s.
Huh.
I’ve had two previous S10’s. Figured maybe I had forgotten that the Dimmer/Headlight plugs needed to be connected or something. So I laid the dash trim back up on the steering wheel and plugged everything in.
I wired the lights to the dimmer. So yea they worked, but nothing else.
No problem. I found the actual illumination wire and spliced the LED strip power onto it instead. Plugged everything back in, checked all the wiring for the stereo harness, checked all the interior fuses nothing. Somehow the gauges came back on, after plugging the harnesses for the headlights and hazards and such back in, but the odometer and stereo still won’t work. No LEDs now either. (Which is, reminding again,wired to the illumination wire now)
NOOOOO idea what tf I did. I also disconnected the battery just out of hope that it was gonna reset. I’m sure it’s something simple, but I am absolutely baffled...
Any suggestions?
NOW.
No lights.
Huh.
Any suggestions?
