1 - 20 of 92 Posts
I have up for testing a Oasis XD2000
A Big thanks to s1043 for lending me his brand new compressor for the testing. :tup:
May I add at 57lbs this thing is a beast!
Here are the pics,
I am going to flow test it temp check it.
And run through a break in for the first weak of use.
Also I am going to measure amp draw and pull on your electrical system
Last I will Boost test it and add the XD2000 To the Boostable List ( I hope)
The motor is :eek:
awesome,
so well built and designed.
It has 8 total brushes!
and the housing is thick in some places 1/2"
Oasis recently sent me quite a bit of data on the XD2000... i'm curious to see how it will compare to what you test it at.
Discussion Starter · #11 ·
I guess the exact same,
With talking to John,
They flow test there compressors almost the exact same way I will do mine.
and they are very realistic with there numbers they do not 'inflate' them in any way
I feal what I find may just be the same things they already have posted on there site. :cool:
'Stevie Joe'
what id like to know is how loud it is compared to other comps...ive heard people say its the loudest comp theyve ever heard and others say it just hums a little and is very quiet :dunno:
Discussion Starter · #13 ·
I will DB meter it for ya ;)
Great point.
Great point.
Ok, honestly, what do you do for a living? I always used to think that I was hard core, but you are on a totally different minitruckin level. If I belived in gods, you would be one of them. :tup: keep up the crazy stuff you think of
Discussion Starter · #15 · (Edited)
Thanks man :tup:
I work as a Tech at the science center and as a robot Tech at a local personal robot co.
Ok here is my test rig,
2X 1,000CCA Batts :) Huge and heavy ha ha.
I can controll the temp at the bench so it is the best place to test it.
The line is a 5/8" line as to not restrict any flow and It will self charge the batts at 40AMP (about what a stock 105amp alt will charge them at in your truck.
I will mesure Volt drop over time to see if the stock system can keep up.
Oh and DB reading is 89db in the A Weighting at 1 foot from compressor at free flow.
I will get more as I start it under pressure.
Right now I am breaking in seals.
Discussion Starter · #16 ·
Now this is interesting,
From my outher tests,
83db 380C
89 db Air Zenith
But those numbers are running at pressure,
so I will update mine as Iget it filling.
Discussion Starter · #17 ·
Almost ready for the flow test woot :)
i knew a guy with one and under load that dude was crazy loud and shook the whole damn truck
Discussion Starter · #19 ·
You like my camera tripod lol works great.
I dug out my vibration meter as well.
I have a graph of head temp vs. time at free flow this thing gets hot with even no pressure lol
Pic up soon of that.
1 - 20 of 92 Posts
