Sorry..I can't help with cable info. I'm running DBW. Cruise and throttle in a few hidden wires.I've heard that a 4.3L cable works. Maybe @Rhotpursuit, @oldeerslayer, @Life is a Enigma, @manbearpig & some others can say for sure.
Motor in there is looking pretty good!
Is that the truck spacing?
Are you putting the radiator inside the core support?
Where did you find the A/C bracket set up?
Ya, it’s the truck pulleys, the a/c bracket it from a pre vortec v-6. Saw that on the lsx forum. My harness and computer arrived today, my manifolds should be here in the next couple days.Found this in here too, look @ post #6
Throttle cable solutions...
So, who all has a cable throttle body with the annoying brass cable retainer with small allen set screw? I've got two problems with it, the first being the cable. My cables constantly fray. I've tried supergluing some of the end. I've tried epoxy which didn't stick. I've tried soldering with...www.s10forum.com
Went to the good old pick and pull, found a 02 blazer with the v-6. They look like there going to work. Got the cruise control mounted, cable looks a little long buts it’s going to work. Waiting on the power steering pulley, rockauto . and the manifolds from holley.Any news on what cable worked for you???
