I replace the slave cylinder,line and master cylinde. So not going into gear with pedal push to the floorboard. I did notice that the clutch pedal isn’t as high as the brake peda. All my other manual cars have the pedal either even or above the brake. Any ideas Because I’m stuck. 2004 Chevy blazer with a 4.3 5 speed
time to get cereal
How did you bleed it? You either need two people or a long pipe or pry bar to hold down the pedal while you open the bleeder.
Does Motive make an adapter for their pressure bleeder that would fit on the master? I use one on my brakes and it works great. One person can bleed a complete new system with all new lines and calipers in 1/2 an hour. Does use some fluid to even fill it and get started. I pour it back into the bottles when done since it is still clean and put tape around the cap to delay it's water absorption.
Well, I think the clutch is shot. Bled the slave cylinder and the pedal is firm. Looked underneath at the slave and it’s moving when my friend press the clutch pedal. This is what happens when you buy something cheap, lol. Cheap fix though. I just hate to inherit someone else mishaps.
