does anyone know who makes bolt in c-notches. How easy are they to install? And do they make your frame weak in any way?
not really b/c the rear of that truck had about 1/2 betweent the ground and the frame when the air was completely let out of the rear.97SS-10 said:does it look stupid when the front is just layin frame and not the back? Do you have to slice up your bed to put in a notch? thanks
until you drag it off that is :uhoh: had a buddy do that once and he ended up runnng off the road cause the axle wanted to go side ways and the truck wanted to go straight.xtremer-pxl said:
You can lay your front leaf hanger all day with a bolt in..
