with an air over the axle set up with the bag mounts welded to the side of the notch is it nececery to weld a bridge across the notches for extra support. Will it be ok with out it.
i've seen multiple setups without a bridge bar and they've all been fine, but none of them were hopped on, so IMO it will be ok as long as you don't try to bounce the thing in the back
thanks for the info!!!! Its an 89 fullsize I was just worried that without the bridge bar that the notch would start to bend outward or the braket would start to bend up after a while. I was kind of noticing that it looks like its bending outward alittle bit but i might be tripping.
