what kind of damages can you do? if you're lucky, you might blow a head gasket and catch it really quick, and be able to save the motor, if you're unlucky, you'll be pulling pieces out of the oil pan, IF they don't fall on the ground because one of your connectiong rods decided to create a viewing hole through the side of your block...moxon4 said:what are the possible damages to my vortec v-6 engine if i get nos. what build up will i have to do????
Psychobrick said:what kind of damages can you do? if you're lucky, you might blow a head gasket and catch it really quick, and be able to save the motor, if you're unlucky, you'll be pulling pieces out of the oil pan, IF they don't fall on the ground because one of your connectiong rods decided to create a viewing hole through the side of your block...
