1 - 2 of 2 Posts
stock again
ok ppl, i have a 3/4 drop on my stepside, and recently i started hearing a starge "ticking" noise, from the fron tdriver side of the truck. i just put different wheels on the truck, and now the "ticking" has become a very voilent knocking at lower speeds. it stop after i hit the brakes.
are there replaceable bearings on these newer s-10's, or can i swap in anew hub? anyone know? i've never really had the front end apart on this thing, except to put the springs in.
check your wheel bearings just jack up the front end and grab the top and the bottom of the tire and wiggle it bakc and forth and see if there is any movement if there is your wheel bearings are bad. they are easy to replace you can do it no problem you just need the right tools shouldnt take more then 15 mins per wheel
1 - 2 of 2 Posts
