Okay, hi good folks! Regarding my chevrolet s10 2.2 2002, the taillights are not working, netiher left or right (brakes, headlight and indicators works). Let me get straight to the already done diagnostics, fuse 10,34 if I remember correctly is good ( so is every fuse as i tested them all). No power to tail light socket, but power to break light socket when brakes are applied obviously. Power to both indicators aswell. I have checked for good ground and redone the ground.
Moving foward I can not see any damages in the wire harness. Now to the headlight switch, everything looks fine on this one, no corrosion. I tried a jumping wire from orange ( live wire ) to LTBLU wire, still no taillights. Measuring on the pins in the fuse holder on DTL i get no power outcome, neither do I get any power measuring when headlight switch is engaged. 0.0 volts on both fuse 10 and 34.
This my good friends begs the question, is it a fault inside the fusebox, bad connection from batt to fuse OR might it mabey be a fauly relay? In that case wich relay activates power to DTL, park light etc? Ideas?
