i have a 98 s10 and when i try the turn signals or the hazards neither do anything. also i just replaced the turn signal flasher and that had no effect. any suggestions would be great.
just went and checked, my brake lights work fine and all my fuses are good as well. and if it helps the normal clicking sound isnt there at all
Electrical Mod
The whole assembly the turn lever is attached to. It's mounted on top of the steering column, it included the hazard switch, the turn signals, wipers and cruise if applicable.
oh okay. and ive always wanted to know, if i get the lever with the cruise control and fill in all the cruise control fuses would it work. and its automatic
Electrical Mod
you'll have to wire it all up, but if you get the switches, you can make it look stock at least. And it wouldn't take too much to wire it up.
