so I recently changed the intake manifold gasket and I changed the oil from the milky coffee to fresh oil but my oil pressure gauge doesn't move when I start the truck. It wont move at all. Could this be a gauge issue or an oil pump issue? The truck doesn't over heat anymore and seems to idle fine. i haven't drove it since the gasket replacement so do you guys think its fine or something to look into. Also after i was done with the replacement the battery was dead. I have had battery issues before so I didn't think anything of it.
Don't worry about the battery, you probably had a door ajar the whole time you were working on it. If you didn't disconnect the battery first like you're supposed to. When ever you work under the hood take the ground cable off before doing anything.
The oil pressure switch is probably disconnected back by the distributor. Or you might have accidently damaged it if it is hooked up.
You just had the distributor out, so you know how to do it. If it's running OK you did it right. Pull it back out for elbow room.
And as Rhotpursuit mentioned you hopefully changed the oil and filter. I'd do it again in a couple days because a lot of crud gets loosened up when R&R-ing the intake.
