1 - 2 of 2 Posts
When I select P (park) it will backlight for a minute after starting and then the high light dissapears leaving just a green P and no backlit "N" neutral either. I just had a power supply in the cluster unit replaced today as one of the turn indicators would not flash. Yesterday, all the gauges went out and I had to bang the lens to get the gauges to work then later they went out; the new power supply fixed the turn indicator light and gauges. Now, I have this issue of no highlight for the N and P gears. The P will backlight on startup then soon after the backlight is gone. So I may try to get the cluster repair dude to look at that. Thing of it is that he can assumlate my situation with the cluster removed; he would see green illuminated gear letters but not the one selected. Thinking of leaving my tuck with him so he could trouble shoot that. I thought the NBSU switch was at fault but was told that has no bearing on the issue.
Picture shows 1st gear selected (back lit).
350575
What's up with your fragmented sentences?
I fixed your post.
1 - 2 of 2 Posts
