1 - 2 of 2 Posts
I have a 1993 S10 four door Blazer with a Vortec 4.3. Would it be possible to put a plastic fuel tank from a newer Blazer under it? Are the tabs on top of the tank the same to mount the older fuel pump assembly? If not, does the newer fuel assembly have the same pressure output?
Sometimes I'm mean...alot
This is the 4.3 engine forum and probably not the best place for this question... I would ask in the "droppin it" and "baggin it" forums if you recieve no helpful reply's here, as those guys are always dealing with gas tank placement issues.
1 - 2 of 2 Posts
