1 - 12 of 12 Posts
First off, i've looked everywhere and spent ages upon ages reasearching SFA in a s10 or blazer.
I plan to do a swap with Ford DANA 44's out of a 77 bronco, a ford 9" rear end also.
The kit I'm using is a sky manufacturing kit for the blazer or s10.
I just have a few questions and would be more than happy if you guys could answer them.
Would a ford bronco dana 44 work with the sky manufacturing kit? or would i need different axles.
And how the do i set up the steering? I've spent days trying to find a setup!
Thanks in advance, amos.
look at the newb guide....?
it should give you every answer you need, and AFTER you read that, still have questions, post in there.
Im really not trying to be a dick. but there are many answers in there for the questions you have asked.
i didnt know you could remove the wedges, thought they were cast in to the axle tubes
If the wedges are cast then you cant but if they are welded on then they can be removed.
Thanks! that help a bunch and now i know how SFA steering works!
For some reason i couldnt really understand it :S
but, you ask if i have an LP? I feel like an idiot not cause i do not know what that means.
Discussion Starter · #10 ·
Yes, its a low pinion Dana 44 off of a 76 Bronco with lockers.
I just need to change the gears to 4.10 because the rear is also 4.10.
Man i feel dumb but what are wedges?
i think those are all the questions i got for this. Other than that im pretty sure i know what im doing.
1 - 12 of 12 Posts
