You like motorized shopping carts too?!?
I wasn’t surprised at all! Looks exactly like I pictured in my head. What a junk s10 you have bro.Dude you don't wanna mess with my dope ass dime.
So you’re done playing now I see. That is pretty bad***!!Brah, this thing's got a quad turbo V12 and 10 18" subs in the back. It's a sick wicked ride fo sho
How would you like a little vacation? And yes...17X8 will fit the back. Did you bother to look at the chart?Every once in a while a dumbass enters into the room, but he’s probably the smartest one in there and doesn’t even know it.
The real question is will 17x8 fit the back?
This chart is made from the experiences I have with the trucks I lowered and put tires on and that still look good not to much wheel well space. Also tire sizes are what I and customers thought looked best on the rims. Not all people might agree on this but most of those who I have helped will agree this chart is fine.
CHART IS FOR S10S/SONOMAS BLAZERS 2WD ONLY HERE
Well this is a chart that should work and help you guys out 6 7 drop and bags here we go. THIS CHART IS FOR THOSE WHO USED SPINDLES AND SPRINGS. THE SPINDLES MOVE THE FRONT TIRE OUT 1/2 INCH.
S10/SONOMA/PRE 97 BLAZER AND JIMMY 2WD
3 inch drop in front
stock s10 rims 15x7 245 60 15
15x7 4 BS 235 60 15, 245 60 15
16X8 4.5 BS 235 55 16 255 50 16
17x7 4 bs 245 50 17
17x8 4.5 BS 245 50 17, 255 50 17
18X8 4.5 BS 245 45 18, 255 45 18
19X8 4.5 BS 245 40 19
20x8 4.5 BS 245 40 20 <--biggest you can go on front with 20s and not rub unless you have bags then you can go lower and lift it
20x8 4.5 bs 245 35 20, 255 35 20 <----bend rims eaxy
4 INCH DROP IN BACK
stock 15x7 s10 rims 255 60 15 perfect
15x8 4.5 bs 255 60 15, 275 60 15, 295 50 15
15x10 5.5 bs 305 50 15
15x10 5.5 bs 295 50 15
18x8 4.5 bs 255 45 18
18x9.5 5.5 bs 275 40 18
18x10 5.5 bs 285 40 18
20X8 4.5 bs 245 40 20, 255 35 20 or 245 35 20
20x10 5.5 bs 275 30 20, 275 35 20, 285 30 20
4 INCH DROP IN FRONT
stock s10 rims 15x7 225 60 15
15x7 4 bs 225 60 15 215 60 15
16x8 4.5 bs 245 50 16
17x7 4 bs 225 45 17, 235 45 17
17x8 4.5 bs 235 45 17, 245 45 17
18x7 4 inch bs 225 45 18, 225 40 18
18x8 4.5 inch bs 245 40 18 <--bigger than this will rub
5 INCH DROP IN BACK
15x8 4.5 bs 295 50 15, 275 60 15
16x8 4.5 bs 245 50 16, 255 50 16, 265 50 16, 295 50 16
17x8 4.5 bs 245 45 17, 255 45 17, 255 50 17
17x9.5 5.5 bs 275 40 17 285 40 17
17x10 5.25 bs 285 40 17
18x8 4.5 bs 245 45 18, 245 40 18, 255 45 18
18x9 5.25 bs 265 35 18, 275 35 18, 285 35 18, 295 35 18
18x9.5 5.5 bs 275 35 18, 285 35 18, 295 35 18
18x10 5.5 bs 285 35 18, 295 35 18
19x8 4.5 bs 245 40 18, 255 40 18
19x10 5.5 bs 295 35 18 you can go 5.75 if you want in bs
20x8 4.5 bs 245 35 20 255 35 20
5 INCH DROP IN FRONT
15x6 3.5 bs 205 60 15
15x7 4 bs 215 60 15
16x8 4.5 bs 225 50 16, 225 45 16
17x7 4 bs 225 45 17
17x8 4.5 bs 225 45 17 tire wil look stretched, 245 45 17 to big major rubbing
18x7 4 bs 225 40 18
18x8 4.5 bs 225 40 18 tire will looked stretched any bigger major rubbing
6 INCH THROUGH 7 INCH DROP IN BACK
15x8 4.5 bs 295 50 15, 265 50 15, 275 60 15
16x8 4.5 bs 255 50 16, 265 50 16
17x8 4.5 bs 255 50 17, 255 40 17, 255 45 17 245 45 17, 245 40 17
17x9 5.25 bs 275 40 17, 285 40 18
18x9 5.25 bs 275 35 18, 265 35 18, 285 35 18, 295 35 18
19x10 5.5 bs 295 35 19
THIS IS FOR THE FRONT BAGGED SET UPS IN 17, 18, 20
17x7 4 inch bs 205 40 17, 215 40 17 225 40 17, 215 45 17 and 225 45 17. the 225 45 17 will hit top of fenders when laid out.
18x7 4 inch bs 225 35 18<-bend rims easy but wil lay, 225 40 18 215 40 18
18x8 will rub bad and at full turn. but you are bagged so a 225 40 18 will work 235 40 18 will rub bad when laid out.
When you want to lay frame anything above a 25 inch tire you will have problems in the front on the fenderwells. You will lay hard on the fenderwells with anything over 25 inches.
20x8 4.5 bs 245 35 20 <--will be fine once lifted up but you will sit on the wells when bagged out
rear bagged
17x8 4.5 bs 245 40 17 235 40 17 245 45 17
18x8 4.5 bs 245 40 18 245 35 18
18x9 5.25bs 275 35 18, 265 35 18
TALLER THAN A 26.5 TALL TIRE WILL RUB THE TOP OF THE REAR FENDERS IN THE REAR IF YOU ARE RUNNING A 2.5 C NOTCH OR MORE.
IF YOU GUYS WANT ME TO ADD MORE SIZES ASK AWAY AND ILL CHANGE THE SPECS.
FOR THE FIRST GEN YOU HAVE TO RUN 18X7 IN FRONT 4 INCH BS 17X8 HIT TIE ROD ENDS. if you run 17x8 will hit the tie rod ends.if you do get 17s then go 17x7 not 8. ALSO IN REAR IVE DONE A FEW 17X8 WITH 255 45 17 OR 18X8 4.5 BS 255 45 18 NO PROBS THE 18X9.5 WITH 275 35 18 AND 5.5 BS WORKED GOOD
THE PRE 97 BLAZERS ARE ABOUT THE SAME AS THE 94 UP S10S BUT THE 98 UP TOTALLY DIFFERENT
On ours we have a 5.5/7 drop and with 255 40 19 rubs at full turn on 19x8 and 4.5 bs but its fine other than that. The rear i tested my 19x10 5.5 bs and 295 35 19 no probs
ok so here are some numbers for a 98 up blazer
stock 15x7 will work with a 235 70 15 with a 4 5 drop.
4 inch drop 98 up blazers
16x8 4.5 bs 235 60 16
18x8 4.5 bs 245 45 18 255 45 18
19x8 4.5 bs 255 40 18
20x8 4.5 bs 255 35 20
rear with 5 inch drop
same as s10s from 17 inches and down
18x8 4.5 bs 245 45 18, 255 45 18, 275 40 18
19x8 4.5 bs 255 40 19
20X8 4.5 BS 245 35 20
20X10 5.5 BS 285 30 20
98 up blazers 5 inch drop in front
17x8 4.5 bs 245 50 17 255 50 17
19x8 4.5 bs 245 40 19 255 40 19
NO 245 40 20 OR 255 40 20 WAY TO TALL WILL RUB TOP OF FENDERS
6 inch drop in back
17X9 5.25 BS 275 40 17, 285 40 17
17X10 5.5 BS 285 40 17
18x8 4.5 BS 255 45 18
18X10 4.5 BS 285 40 18
19X8 4.5 BS 255 40 18
19X10 5.5 BS 295 35 18, 285 40 19, 295 40 19
20X10 5.5 BS 275 35 20, 285 35 20, 275 30 20, 285 30 20
Lol I know this is a old post but thank you so much for this. I am building a 1991 gmc sonoma with my 16 year old son and this is one of the major question I have and you answered it is such detail thank youThis chart is made from the experiences I have with the trucks I lowered and put tires on and that still look good not to much wheel well space. Also tire sizes are what I and customers thought looked best on the rims. Not all people might agree on this but most of those who I have helped will agree this chart is fine.
17x7 4 bs 245 50 17
4 INCH DROP IN BACK
5 INCH DROP IN BACK
15x7 4 bs 215 60 15
17x7 4 bs 225 45 17
18x7 4 bs 225 40 18
rear bagged
6 inch drop in back
17x7 4 bs 245 50 17
4 INCH DROP IN BACK
5 INCH DROP IN BACK
15x7 4 bs 215 60 15
17x7 4 bs 225 45 17
18x7 4 bs 225 40 18
rear bagged
6 inch drop in back
[/QUOTE
Can I fit 235 55 17 rims and tires on my stock 2wd 97 S10what would you suggest on a 98+ bagged... i was lookin at 18x8.5 in front and 20x8.5 in back... what tire sizes? and im also using djm spindles instead of the belltechs, i heard the djm spindles dont push out your wheel like the belltechs... help plz, thanks tony
ThanksSure, if they have the proper backspace and lug pattern.
What size tire do I need to run on 17x7 on a 1994 s10 stock no lift or loweringThis chart is made from the experiences I have with the trucks I lowered and put tires on and that still look good not to much wheel well space. Also tire sizes are what I and customers thought looked best on the rims. Not all people might agree on this but most of those who I have helped will agree this chart is fine.
17x7 4 bs 245 50 17
4 INCH DROP IN BACK
5 INCH DROP IN BACK
15x7 4 bs 215 60 15
17x7 4 bs 225 45 17
18x7 4 bs 225 40 18
rear bagged
6 inch drop in back
Nice truck pics, but doesn't offer any help to the op. Perhaps you posted in the wrong thread by mistake?
Lmao, well we can tell who the newb is. You'll need skin thicker than the sidewalls on those rubber bands you got there.Smart ***, 20 x 8.5 is specs. 4/5 drop if it makes you happy. This is supposed to be a place where people share and get along, not run their mouth from the comfort of their electronics.
