Just Call Me Dick
i have not put in a corvette servo in a 4l60e but i have on many 700r4 (even mine in my 2.8) and 4l60. i have never tried to cause the people that come in with 4l60e never ask for them. so i am not sure if it works.
Do both the 700R4s & the 4L60Es use the same parts? I'm wanting to install a corvette servo, OD servo, tv boost valve, & low, reverse boost valve. So far I only see the different valves listed for 700R4s, so I was just wondering if they would work in a 4L60E also. Thanks.
the servos will interchange. some of the valves can with modifacations but its not worth the time. the tv valve only will work in the 700 ,the 4l60 is electricly controlled. sonnax makes a pr boost valve for the pump in both apps. they also make a tcc valve to correct one of gm's mistake in the 4l60e along with an actuator feed oil limit valve wich is also for the 4l60e. sorry if this is confusing , ill' clarrify later if needed.
