the ones on it are probably fine but i like to keep my eyes peeled for deals and i dont see these anywhere i have looked
There are spring shops that can make springs, coil or leaf, to any specs you need. I've got 26 years and 300K+ on mine and they don't seemed to have sagged at all.thanks, I am looking for new ones though... I almost have every part to totally overhaul the truck at this point and i figure i may as well get the springs done as preventative maintenance. i wanted to do new rear shocks and springs together. i suppose the new bilstein rear shocks are technically 'non-zq8' so i could do some trickery back there as long as it maintains the xtreme lowered stance, whatever that is... but i would prefer new zq8 springs to just keep it simple... but i suppose new 'zq8' rear springs may be a custom build in and of themselves...
on a side note, i have a few sets of 'helper springs' that are the add a leaf-style... supposedly they add carry capacity... just wondering if anyone has ever used them on an xtreme or zq8? thoughts/impressions?
i rarely need them but i have considered adding them in just to see what they do... they were free and appear to be fairly 'easy on, easy off'...
Helper springs and add-a-leaf’s have been mentioned in threads here. They are different products, and have different effects on ride height and harshness. In my experience, helpers tend to have little effect on unloaded ride height and limited contribution to ride harshness. A Pro Comp 13120 Add-a-leaf kit installed on a RWD, regular cab, stock Z83 w/ ~70k miles increased unloaded, rear ride height ~1.5-2.0”. That trucks ride is a bit harsh, but it also has poly body mounts because OEM style rubber mount cushions are so expensive.true. they havent sagged and its usually empty back there...
maybe i will shelve this one.
i havent found anyone who has used helpers on an s10, which is kinda odd in my opinion bc i would think somebody would have pushed one of these beyond limits... but i suppose those guys probably killed those s10s long ago and are beating on colorados now...
ok, yeah i have two different types of 'extra spring' products for the rear: one is called 'over leaf spring assists'... the other product is a pair of 'helper' coil springs. i dont even know where those coils would/could mount up on a 2wd s10Helper springs and add-a-leaf’s have been mentioned in threads here. They are different products, and have different effects on ride height and harshness. In my experience, helpers tend to have little effect on unloaded ride height and limited contribution to ride harshness. A Pro Comp 13120 Add-a-leaf kit installed on a RWD, regular cab, stock Z83 w/ ~70k miles increased unloaded, rear ride height ~1.5-2.0”. That trucks ride is a bit harsh, but it also has poly body mounts because OEM style rubber mount cushions are so expensive.
nice. i have never seen something like that before. that looks good... and pricey too i bet.I have been using th Road Master Active Suspension for 20 years -- absolutely luv em'. Stock photo below (not my rig)
Whoa! Over $500 on Amazon, $499 on Jegs and Summit...I don't think I paid anywhere close to that (ima cheap hack guyand pricey too i bet.
That said, I'd put money into quality suspension parts before wasting $ on "brand name" shocks.DAYTON 221141 on Rockauto Would cost me $400+ shipped for a pair.
If you want new but can't find ZQ8, just get a regular set and pull out the middle leaf. It will be obvious when you lay them side by side which one I'm talking about.
so along these lines, what is the stock zq8-xtreme height vs a base-stock spring height vs base-stock spring minus the middle leaf height?Just buy stock springs and lower it back down with blocks. The ZQ8 package wasn't designed for people who want to use their truck as a truck.
