teddy get the 17x8 front 4.5 bs and rear 17x9.5 rear 5.5 bs
tires 245 45 17 front rear 275 40 17. rims and tires with locks are 1500 bucks
now if you go with the bfg 245 45 17 and 285 40 17 kdws the tires are like 650 buttt man they look real good. also the bfg tires run wider and a 285 40 17 is pretty close to your stock size so speedo will be right on.
I'd do 17's w/a 45 series Profile (ex. 245/45ZR17) So you don't need to reprogram your computer. if you change the height of the wheel and tire, your speedometer will change.
