G
i drive a 2000 s10, its lowered 3,4 using belltech components, the problem is its not low enough!!!, im very interested in airbags but im not really ready to cut my bed up just yet, is there any way not to c-notch you frame? if so will it cause axle damage?? any help will be greatly apprieciated
praise the lower'd
yah the airride kit that i have you dont HAVE to cut the frame. i did i just put s c notch in. they give you some really short bumpstops that you mount on your frame so you dont dammage you axle/frame. talk to larry @ http://www.innovativeairsuspension.com
he know his stuff,
laters
scott
G
he know his stuff,
laters
scott
so how low can you actually go without a notch? does the rid quality change depending on a notch ?
praise the lower'd
geting a notch wont change the ride at all. the air pressure and shock you use will detrmine that. well the bag too. but i notched mine and added a 2" block for my 2 1/4" (about) notch. it rides pretty good. i have only driven it for 2 days so i havent fine tuned it yet. but if you dont notch you will be like +/- 5" off the gound when you are deflated. depending on your tires.
laters
scott
Treadwear Waste'n Member
I've got the airride 4link, and with no notch and no blocks, my frame is 2" from the ground, or 23" from the ground to the top of the wheel opening. My ride hieght it set at 25" and I haven't bottomed out once :thumbup:
