need to install a new stereo in my 97 s10 but i can't get the dash off around the steering console.... any help....? :cry:
I'm BLOWN
check under the steering wheel..if you've already removed the lower trim panel then there should be 2 screws you remove..then if it's an auto put it in gear and just pop the trim panel off and remove the wire harnesses and your done..hope this helps some
