Where are you stuck?
-Chris
remove all the air inlet tubing(this should be simple enough)then remove the vacuum hose from the valve cover that attaches to the box .Unscrew the hose clamp on the throttle body and take out the one 10mm bolt at the front of the box going into the valve cover. After that just unplug everything from the throttle body and take out the four 10mm bolts holding it in.
