Hi I've been reading and using your guys post, guides, how to's, and debates quit often. Even before signing up. 1st time posting so please forgive me if it's not where it's supposed to be or anything else. Also at this time I'm stuck using my phone. So please forgive me if missing punctuation etc. Can't honestly say would probably be much better on the comp.
Have a few and then some questions. On this forum I've dug off on pretty extensively but with no success or only bits of info found that isn't enough or enough for me to figure it out. Doesn't mean its not somewhere on here. Just I'm about to run out of time on a few of these. The Sonoma isn't to heavy to push; but the heat might kill me doing it or the traffic on hwy. (Houston / N. Of)But alot Less questions than would've had though.
-Has anyone came up with a way to bypass manual fan pulley? ( Or any wild might work overt hought or under thought ideas) 2 reasons. 1st bearings going on mine. Found the bracket / fan pulley bearing housing. Just that cost for what should be $15 bearing. The real irony for a pulley don't need anymore. ( Did E-fan mod)
-Since going to have to pull that bracket to replace it / the bearing. It's probably more than time to replace the timing chain or at least as preventative maintenance ( Don't know if has ever been done or not and at 187k) Just like everyone on here though. Have put alot of time,money, and work to bring this truck back to life. To have it jump time on me after everything would be heart breaking and wallet couldn't take it lol. Reading through the forum everybody says go with OEM ACDelco (always agree on this) looking and digging through about any parts place I know of or can find online. It's either discontinued on the GM ones and dealer. Or I'm only able to get just the chain that's AC Delco and not the whole setup being chain, tensioner, and gears. So if anyone knows were can order ACDelco for less than a mtr. Or the 2nd in line for longevity (very hard comparison i know) please let me know. (Looked at the tensioner eliminater one but reading through forum seen alot of don't do it warnings just nothing completely definitive as to issue)
- Rebuilt my a/c compressor last year ( had time and never rebuilt one before plus Im tightwad when chance of diy projects) worked out great after getting bearings pressed out was alot easier than thought it would be just make sure to set gap correctly on clutch. Then just like me luck seams to go alot more than not. A few months ago had no cold air. I had put the dye in just in case. Turns out the line they routed under compressor and over towards passenger side has a leak right after crimp were rubber starts. After doing compressor last year was when I found out about upgrading system to the newer style compressor. Little late though.
Is there any way to use the newer line think they call it suction line or anyone figured out how to route that line around the front? Or any other way besides below the compressor.
-The floor vent constantly blowing and blowing harder the faster you go. I read a few different post over it but.. Had no success with the fixes I did see. One was detaching grey line from the system. Didn't effect floor vent issue for mine. When I replaced the heater core I checked and went ahead and replaced all vacuum actuators as well as the 1 motorized actuator. Checked each vac. Line and the switch for the system. Resealed the floor vent door. As the flap was rotted.
- I know crammed alot of crap into one sorry. Post ( just trying to be like the engineers when they did this 96)
Last one for awhile. I read a post on here. That can supposedly remove abs and run lines into master cylinder without adding proportion valve. Drum in back disk in front. Does that seem accurate to anyone?
96 gmc Sonoma extended cab SLS. 2.2l 5 speed (think its the NV1500) built in jan. As found out last yr has the really one off head that the head gasket is pain in *** 2 find.
