1 - 14 of 14 Posts
Are you sure that mirror is out of an S-series? I'm only seeing 3 and 5 wire connectors on 2nd gens. None with those colors. Is the 4th wire lt blu or green.
I looked at every courtesy lighting diagram from 95 to 2001 and didn't see any 4 wire mirrors. 3 for the standard lighted mirror and 5 for the electro-chromatic ones. They're wired to the backup lights so that when you are in reverse the auto dimming is turned off.
Discussion Starter · #10 ·
I believe it is a2000
S
Hard to find without knowing the year, model, etc.
I'm sure it is a Sonoma
There's a blue One and a light blue one and a yellow one and a brown
I looked at the 2000 Sonoma courtesy lights diagram. 3 wires for regular mirror and it's actually 7 wires for automatic day/night mirror. Orange black and white for base mirror. Light green, brown, pink, gray, orange, white and black for the automatic mirror.
What is the mirror out of?
Well shut my mouth! I looked on 2 different brands of wiring diagrams and they both showed 3 or 7. Guess I should know by now not to believe everything I read. Do like the fact the replacement connector has every wire the same color. That should make hooking it up fun.
Rectangle Electronics accessory Metal Composite material Electric blue
1 - 14 of 14 Posts
