awhile ago someone posted about the oil pressure dropping when engine is under a load. i couldnt find it anywhere. anyways my problem is at an idle and normal driving the pressure is fine when you get into the throttle the pressure drops 10-15 lbs. can anyone help me please.
i saw what you did there!
probably just bad sending unit
pretty common issue with these trucks
mines pegged out past 80psi always and it never moves and i dont worry about it
ive never seen a s-10 oil guage that worked right, i dont think one exists.
are you using stock guage and stock electric sender?
or?
if your engine isnt rattling or overheating then id not be worried about it
