I have a 92 s10 blazer 2 door and the oil cooler lines blew up I've taken off the cooler and now I'm trying to put the filter back onto the block. I cannot find a adapter part that fits. if you had something work for you let me know.
I’m not sure what you mean when I took the plate off for the oil cooler there is no screw it’s just a threaded hole and 2 holes to screw the cooler plate back onRemove the adapter from the block (2 bolts), unscrew the filter nipple from the adapter & simply screw that nipple directly into the block. Filter will screw on easily, but make sure you scrape all the old gasket material from the area where the filter o-ring seats.
I will put a picture of what it looks likeI’m not sure what you mean when I took the plate off for the oil cooler there is no screw it’s just a threaded hole and 2 holes to screw the cooler plate back on
It's on the rear of the block. The pic above is from a 4wd and that's the front drive shaft on the left. Makes it a tad tricky getting the filter off and back on.
The nipple can be hard to unscrew from the adapter w/o messing up the threads. I cut one adapter with a cut off wheel to real close to the nipple and then cracked it. It's aluminum and cracks easily. You won't hurt the steel nipple. I've seen some nipples with a big hex hole inside for a big allen wrench. 3/8", IIRC. Might be bigger.
So are you saying I have the adapter? I don’t see how I would unscrew itIt's on the rear of the block. The pic above is from a 4wd and that's the front drive shaft on the left. Makes it a tad tricky getting the filter off and back on.
Like ODS said...some of the have a hex in the middle of them.So are you saying I have the adapter? I don’t see how I would unscrew it
I’ve used that and it sits flush with the mating surface so I can’t get a filter on thereMaybe he needs something like this?
GM Genuine Parts 14081300 Oil Filter Fitting
Buy GM Genuine Parts 14081300 Oil Filter Fitting at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!www.amazon.com
I just got one of those in the mail and went to mount it up and it didn’t even go into the block so I could bolt it it says it’s for a small block Chevy but I guess not the 4.3
That's weird. I did the same thing you're trying to do, and I used the GM 14081300 that OCGG posted. It worked perfectly, with no issues. But mine is a 2000, so it may have changed.I just got one of those in the mail and went to mount it up and it didn’t even go into the block so I could bolt it it says it’s for a small block Chevy but I guess not the 4.3
