can anyone help me find what every option is aval. for a 2000 s10 ext. cab. ZQ8?
Because I got this truck used and I think it has every option even the block heater!
I just can't find a list of options anywhere maby a window sticker? or Maby I can call GM?
Hey thanks for that link!!!
Here is a list so far but some did not work! Did i put them in right?
Man there is alot.
AJ1 WINDOW TINTED , "DEEP, ALL EXCEPT W/S AND DRS"
PC4 WHEEL , "14 X 6, STEEL, STYLED"
K34 CRUISE CONTROL , "AUTOMATIC, ELECTRONIC"
SLA PLANT CODE , "SHREVEPORT, LA, USA"
V73 VEHICLE STATEMENT , USA/CANADA
ZQ8 CHASSIS PACKAGE , SPORT
ANL SALES PACKAGE , "AIR DEFL, FOG LP"
DK2 MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, HEATED,"
K60 GENERATOR , 100 AMP
SLM SALES PROCESSING , STOCK ORDERS
XCB TIRE FRONT , P235/55R16-96T BW R/PE ST TL AL2
ZY1 COLOR COMBINATION , SOLID
D55 CONSOLE , "FRT COMPT, FLOOR"
L43 ENGINE , "FLEXIBLE FUEL, (GAS/ALC), 4 CYL, 2.2L, MFI"
T61 LAMP SYSTEM , DAYTIME RUNNING
X88 MARKET BRAND , CHEVROLET
15B TRIM COMBINATION , "CLOTH, SHALE (B) (95),"
15B TRIM COMBINATION , "CLOTH, SHALE/NEUTRAL (B) (97)"
AU3 LOCK CONTROL , "SIDE DR, ELEC"
EVA TEST , "DVT, EVAP EMISSION REQUIREMENT"
M30 TRANSMISSION , "AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC"
UA1 BATTERY , "HIGH CAPACITY, WET"
YCB TIRE REAR , P235/55R16-96T BW R/PE ST TL AL2
AV5 SEAT , "FRT BKT, HIGH BACK"
E24 DOOR SIDE , "REAR, HINGED"
NF2 EMISSION SYSTEM , "FEDERAL, TIER 1"
UP0 RADIO , "AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH"
YC3 CONVENIENCE PKG , DECOR LEVEL #3
12H TRIM COMBINATION , "CLOTH, GRAPHITE (H) (96)"
A28 WINDOW RR , "FULL WIDTH, SLIDING"
E62 BODY EQUIPMENT , "STEPSIDE, PUBX"
NP5 STEERING WHEEL , LEATHER WRAPPED
UP8 RADIO , "PROVISIONS, AM/FM STEREO, INSTRUMENTATION"
YD3 AXLE , (BASE EQUIP) FOR SCHEDULING GVW PLATE
121 Unknown RPO Code
A31 WINDOW , "POWER OPERATED, ALL DOORS"
FE9 CERTIFICATION , "EMISSION, FEDERAL"
N33 STEERING COLUMN , TILT TYPE
U16 TACHOMETER , ENGINE
YD5 SPRING FRONT , BASE EQUIPMENT
500 Unknown RPO Code
B30 COVERING FLOOR , CARPET
GT5 AXLE REAR , 4.10 RATIO
N40 STEERING , "POWER,"
U73 ANTENNA , "FIXED, RADIO"
YD6 SPRING , "RR, BASE EQUIPMENT"
6MM COMPONENT FRT LH , COMPUTER SEL SUSP (6MM)
B32 COVERING FRT , "FLOOR MATS, AUX"
JM3 BOOSTER , "BRAKE, 240MM TANDEM, HIGH FLOW"
N96 WHEEL , "16 X 8, ALUMINUM CAST"
NF6 EMISSION SYSTEM , "FEDERAL, ZEV"
7AA COMPONENT FRT RH , COMPUTER SEL SUSP (7AA)
7MM Unknown RPO Code
C3A GVW RATING , "4,400 LBS"
K05 HEATER ENG , BLOCK
QCB TIRE ALL , P235/55R16-96T BW R/PE ST TL AL2
VXS VEHICLE , COMPLETE
ZQ3 SALES PACKAGE , DRIVER CONVENIENCE II
C60 HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS"
K18 REACTOR SYSTEM , "AIR INJECTION, ELECTRIC"
RSA RESTRAINT , "FRT SEAT, 208, AUTO, PASSIVE"
V10 PROVISION OPTIONS , COLD WEATHER
ZQ6 SALES PACKAGE , DRIVER CONVENIENCE III
