I just did a plug, wire and distributor cap/ rotor change and it's running rough. Can someone tell me what the firing order is? On the pass. side of the cap it has 2-4-6 from front to rear.
But on the driver's side it's 3-1-5 front to rear. Is that correct?
I have a Chilton's manual and it says it's 1-3-5 front to rear. So I'm alittle confused which wire goes to the #1 and #3 cylinder. I'm thinking I have them messed up.
The cap is marked correctly.
What is confusing you is that the firing order is determined by engine internal design.
The cap is marked to show where to put the plug wires for the correct connection.
