Ok so I bought this s10 a week ago. and been trying to workout all of the "bugs". starting with the cts, my dash temp gauge wasnt working. The guy before me put an aftermarket gauge in but I know that won't work because the ecm doesn't see the sensor. So it causes the engine to flood out and hard to start. So I bought a new sensor and put it in ,then bought a new connector, and still no gauge and its still throwing the sensor code. Ive tested continuity from sensor to ecm and all is good. Then tested continuity at cluster to sensor and had multiple wires reading continuity. Also changed the cluster still same issue is the problem in my ecm?.
