1 - 11 of 11 Posts
i got a posi 7.5 out of a olds bravada but the problem i have is that the axles in my rear end are a 26/27 spline while these one are a 30/31 would axles out of a 4x4 s10 have the larger spline or where would i go to find them....
Project: Sabriel
um...s-10's have either 26 or 28 spline axles im pretty sure, so i dont think it would fit, but im not totally sure
i just counted the splines on the axle and they are 26 and the posi is 30 but i was wondering where i could get the axles for this posi... i got the posi off ebay otherwise it would have been wise to get the axles too
no your right it's a 28 spline just counted eyes get dizzy trying to count them inside... are they found on 4x4's
Project: Sabriel
yeah, the 8.5" has 28-spline, and i think some 7.625's have 28 spline, best thing to do is go to a junkyard and source them there, or order them from a truck parts magazine, or store
you wouldn't happen to know if the newer s10 axles with the 28 spline are the same lenght as those in a 86 s10 do you
LEAD FOOT LARRY
The 28 spline axles are the same length as the 26 spline axles.
Some of the blazer and 4x4 axles are different lengths.
There is a debate when GM went to 28 splines, 88 or 89.
If the posi you got if for a 7.5 rear then you can just get 28 spline axles out of a newer s10 with a 7.5 rear. The 26 and 28 spline axle shafts are the same length and also use the same bearing and seal and the wheel.
sorry ment to say at the wheel not and the wheel
1 - 11 of 11 Posts
