I have a 97 chevy s10 pickup. I was told I need a new center link and idler arm. My friend took a look at it and said I only needed a new center link.How do you know if you need a new center link? How do you know if you need a new idler arm? Can I get an alignment without replacing thoses parts?
No longer a pizza tech.
Most shops will not allow you to get an alignment with a worn out front end, because then the alignment is useless.
When the idler arm goes bad, your truck will start floating all over the road. doesnt want to stay straight. Center link im not so sure, i took my truck in to get an alignment and they told me it needed replaced, so i replaced it.
I can change lanes to the right by letting go of the wheel
thats partially because your alignment is off. Im talking more like the front end feels worn out instead of nice and tight at the steering wheel.
Premium Member
When you turn the wheel slightly the truck moves the direction you wanted to go.
Mine, I have slight play.. meaning there is slop in the wheel I can turn the wheel both directions slightly and not affect the direction of the truck.
do a dry park test....with engine off have someone bounce the steering wheel back and forth as you look at each connection point in steering linkage you will see slop in the parts that are bad
