******* Off-Road
Guy's I need help bad. I just got a set of 235/75/r15s mounted on my camaro rims after seeing the same thing on another S-10. They rub real bad from 3/4- full lock. What can I do to fix this. I've already beat the hell outta the innder fender with a sledge hammer. Didn't work? Taking tires off isn't an option. Need some cheap fixes as I've only got $100 to work with. Spacers? Take off inner fender and liner? Something...As I need to do it tonight:eek: As I'm leaving for a trip in the morning:eek:
SoCal Mini-Trucker n FL
Did you keep the old set of tires? If you did, just put the front set back on until you can lift your truck the way you want it.
******* Off-Road
Had 3 flats in 2 weeks. I was rolling on my dads wheels, but he has to start driving his truck so I had no choice. These were the only agressive tire they had that was small enough or so I thought. I couldn't get stuck on wet grass again. But I just went out and off roaded the thing. COULD NOT get stuck:bowdown: and I went through some thick clay and she did pretty good. Then I made it climb a 8" ledge, and she crawled right up:rock: Back tires just dig right in and pull me forward:D So it ain't THAT bad...I just can't make sharp turns, so for now I'll live with making wider turns, and running up and over curbs;)
Lift It
Ther's a few peeps sellin' lift parts in the sellers market place, so maybe you'll get hooked up on a lift soon. Then everything will be right again.
******* Off-Road
Thanks for the heads up:) I'll check it out now..
