1 - 18 of 18 Posts
Newbie for Life
I am on my forth set of plug wires since I got the Jimmy a couple months ago. I have tried about every Autozone brand, including Bosch, but I having no luck. I need to know what is a GOOD high temp set. Everytime I check the staight boot closest to the driver side headlight is completely dry rotted. Also, please let me know a good place to purchase them. I really appreciate your help guys, this Jimmy is really starting to piss me off.
Been there done that...:banghead: Quit messin with aftermarket and get oem:bowtie: Kinda spendy but they work like they were built for it...
BryonC17 said:
Already burnt through AC Delco.
Already checked all the obvious stuff?? laying against headers/manifold...not rubbing...using wire looms?? If you keep throwing money at new wire sets it might be worth it to let chevrelot replace them. My dealer offers lifetime warranty on them. They might have some insight on your problem, or at least look a little harder if they have to replace too many sets.
Newbie for Life
I used electrical tape to keep them from rubbing anywhere on the engine compartment. The wires boots are dry-rotting. How much would it cost to get done at a dealership?
Hold on to your wallet...the wires are$140..probably about 1 hr labor. I was having a major engine performace problem. Had my injectors replaced, but turned out my ignition was lighting up the engine bay. they replacer the wires $140, cap $45, rotor $20, and plugs $6ea. Along with the diagnostic. the tab was just over ...$600. It was a shock but like I said...lifetime on the wires and it runs great...Sometimes it's hard to do better than oem
BryonC17 said:
I really think that the issue is the heat getting to the boot. That is why I am looking for a high temp set.
The question i would be asking myself is..is everyone having the same problem. I had well over 100,000 miles on mine before they puked. i really think there must be some other cause than heat. If it is heat related...why just the one?? Try a little dielectric grease on the boots also...
Newbie for Life
Discussion Starter · #9 ·
I have noticed it happening on more than just one, it just seems that one is going the fastest....I wish other people had the problem so I knew the solution. I keep buying wires with warranties so I am not really losing money. I relly don't have the money to spend to take it to the dealership, and I would really hate to think that I was paying to get parts installed that I didn't need. I am going to try that dielectric grease.
My-chilled, MACH boost
U might be running too lean. Try looking in there at night after some active driving, Maybe red hot?
Newbie for Life
Discussion Starter · #11 ·
What would cause me to run lean? I am wondering if the cause may be heat shields being removed during my engine swap.....
NTBSSHEVN
Dude u just answered your question.
Why are my wires burning?
Becuase u removed the heat shields.
[ I am wondering if the cause may be heat shields being removed during my engine swap..... [/B][/QUOTE]
Sometimes you can't see the forest for the trees...:uhoh:
Newbie for Life
Discussion Starter · #15 ·
I am not positive all of them are off, I am going to check tommorow. I am just trying to think of something that would cause this.
1 - 18 of 18 Posts
