1 - 13 of 13 Posts
frame layin member
i dont wanna lose anyleg room on this. i'm gonna take out my jack so i'll have more room. i need to know the best subs to get with a reasonable price tag. also what kind and size amp. does anyone have 3 in thier truck? i need some dimensions for a box. what to use for the box? 3/4 mdf right? thats what i gather from other threads. also what guage wire to run. thanks in advance.
frame layin member
Discussion Starter #2
nobody? :confused:
drag~N~spark
if ur gonna run 3 subs, go with either jl audio or mtx, and get a amp that has a really low impedence-stable. dont have any box dimentions, but follow what ever the sub specs. call for, then go from there. power wire..... use 8gauge or lower gauge depending on how many amps you are wanting to run. and throw in a distrubition block to keep it all safe!
frame layin member
which model of jl's or mtx. there are several. what would be a good amp to run 3 10's off of. should i go w/ multiple amps or just get one?
drag~N~spark
well that all depends on what kinda money you are wanting to spend. you can be consertive, or go all out!
you can run a mtx 500d for all 3 6000, or 8000 series mtx subs, they will play all day and nite
and im not sure on the amp for jl audio... but run a w6 series sub from jl.
both of those subs and amp can play/be connected together runnin all 3 subs
amatuer porn star
if you check out the latest issue of minitruckin( the one with the blue/yelow/white tacoma on the cover) theres a toyota with a sic azz fiberglass box built into the rear wall of his cab.it looks as if it take up very little room.
make sure the subs you pic take up less than 1.0 cu ft of airspace if your trying to lose as little space as possible.:soap:
drag~N~spark
not to be a whore or anything, the latest issue of minitruckin is MAY2002 it has a orange 86' Mazda pick-up with a hot blonde in a skimpy 2 piece!
frame layin member
Discussion Starter #8
what i'm wanting to know is what would be a good sub to get that requires a small amount of airspace. do the mtxs and jl's need alot of airspace. i'd be willing to spend up to 200 a sub if i have to. i just need to know what brand and model to get. i'm probably not going to fiberglass a box because i have no skills but i can build one out of wood.
amatuer porn star
polk audio makes subs for low airspace so do image dynamics
frame layin member
Discussion Starter #11
i was lookin at some rf he2's they say they only require .375- 1.75
what do you think of those?
Visual-Insanity.org
Its a Peach 86 Mazda... bagged... bodydropped... with grafx...
The truck is From Subculture... :) I know..."FO SB" heh
Image Dynamics
Hey man, Check out Image Dynamics Idq's. There optimum airspace is .5 cubic ft per driver and can go down to .25 cube ft if needed. They have excellent SQ and slam very good as well.:cool:
1 - 13 of 13 Posts
