1 - 1 of 1 Posts
ok i got 2 type s 12 in subs, well i got a pioneer premier GM- 7150M and i was wonder i should buy another one of them and hook one sub to each or but one of these:
Alpine MRP-M650
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 400W x 1 (0.08% THD)
Per channel into 2 ohms: 600W x 1
Brigded 4 ohms: 1000W x 1
Class-D
1 Channel (Mono) Operation
Thermal Management Processor
Subsonic Filter
Bass EQ Circuit
Selectable Crossover (LP)
Adjustable Crossover (LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
MOSFET Final Outputs
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Speaker Level Inputs
Gold Plated Power Screw Terminals
Gold Plated Speaker Terminals
Non-Fading Pre-Amp Output
4-Layer Glass Epoxy PC Board
OR:
Orion 600D
1 X 250 @ 4 Ohm
1 X 400 @ 2 Ohm
1 X 600 @ 1 Ohm
Selectable 12/24 dB/octave variable low-pass filter
Intelli Q bass optimization circuit and remote gain option Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
Copy/Master feature supports gain and crossover adjustment matching in multiple amp
Switchable phase invert function Allows external bridging of two matched gain amplifiers
Heavy gauge direct-wire high current satin finish power and speaker terminals
Heres the specs on the pioneer premier GM-7150M:
2-Ohm Mono Stable
Variable Crossover (40-240Hz)
Selectable Bass Boost with Wired Bass Remote
Peak Music Power: 800 Watts
Load Impedance Capability: 2~8 Ohm
Continuous Power (4 ohm): 250W x 1
Continuous Power (2 ohm): 360W x 1
Total Harmonic Distortion: 0.008%
Signal-to-Noise Ratio: 100dB
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
2 Channel RCA Inputs Gold
2 Channel Speaker Level Input
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF
Bass Level Control 50Hz, 0/6/9/12dB
Dimensions 12" x 2-3/8" x 12-3
Which would be the best for my type s: 2 pioneer premier GM-7150M, or 1(maybe 2) alpine MRP-M650 or 1 Orion 600D? So basically what would be the best setup for my subs? If a better amp let me know thnaks
1 - 1 of 1 Posts
