how can i fix my sloppy steering wheel and im bagged and it is sloppy wen i try to turn the steering wheel the wheel doesnt go back around like it is suppose too any ideas why HELP!!!!
i jacked up the passenger side and it has some movement up and down and side to side im not sure if it is the wheel bearing or a arm or somthing small any ideas
HELP
Please use some caps and punctuation so that your question is readable. If you're using talk to text, stop.
Some specifics would help. What year and model? What mods have been done to the suspension? By who?
Miles on the steering gear?
Check ball joints and all your suspension linkages to be sure , any loose movement will need to be repaired .
Merged Threads.
