1 - 20 of 115 Posts
layn frame N flyn sparks
well here is my rear bag setup. right now its a mono leaf 4" drop blocks and a 2" c notch. I dident cut the bed and im still running dual exhaust so im happy. This weekend ill be baggin the front. So I hope it goes well. So let me know what you guys think.
Jay
Discussion Starter · #2 ·
heres down
heres the duals
www.AcrophobiA.net
looks sweet to me man......i like it a lot cause its bagged and its white like mine:D ...........i would really like to see apic of the whole truck.........can you cut out a small whole for the pumpking so you maye be able to lay????? that is a suggestion so you dont have to cut a big bulk out of the bed
amatuer porn star
are you using the 4" angled block?hows you pinoin angle?
im running the same setup in my rear w/ 2" flat block but my bags are mounted behind the axle....and my pinoin angle is all messed up im waiting on some 4" angled blocks in the mail.
we did cut a small hole in my bed and i layout all the way on 17" rims
want my #... 911 beotch!!
actually, now that i think about it, i have seen pics of the GM pan welded into the bed and it look pretty damn sweet, i was thinkin about it but am gonna french my plate into the bed at an angle and weld up a smoothie pan:thumbup:
question for you./
i have a 2.5 notch and with a 6 inch drop in back am at 23 3/4 to top of fenderlips.
if i get a 4 inch block 22 3/4
right now i bottom out on the notch and the same time pumpkin hits the bed so im cool. what does your truck measure to the top of the fenderlips when bagged out and what tires are you running?
tony
www.AcrophobiA.net
you could always tub the rear ss and run the KP link cause the bags are behind the wheel......that would look nice with yours being a ss
www.AcrophobiA.net
i think the reason is cause it is a bolt on.....im sure you can find a weld on canti lever or fourlink....that should do the trick
Discussion Starter · #14 ·
Well I was thinking about cutting out my bed but I use it to haul a lot of stuff sometimes so I probably wont cut it till we finish the work on my house. I think it will lay out if I cut the bed bacause I have about another inch of drop till it bottoms on the notch if I remove my bump stops.
Right now im running a single leaf with two 2" flat blocks stacked, I had them laying around my house so I decided to use them until I get 4" angled blocks. I havent had a problem with drive train vibration but after I drove it around my trany started to leak from the rear seal. I had to move the entire rear end back about a half inch. I guess it went so low the drive shaft went in to far. My pinion angle is off but not by too much, I shimed the back of my trans below the mount to help it, I guess it worked because I can drive it slamed with no problem.
My tires are 215 65 15 and when I lay it out my fender measures 21 1/2" ill post more pics in a few days after I bag my front, I plan to do it on sunday. My shocks are alredy relocated and the vales are hooked up, just need to cut the spring pocket and put in the bags.
I wanted to keep my exhaust because I think it looks cool, and I dont see bagged or slamed trucks with full exhaust to often. Im planning to weld on my roll pan and shave the plate lights. Probably wont happen for a few more months I have to finnish up body working and painting my brothers regal first. But before I start work on his car again Im gona finish baggin my truck:D
Jay
www.AcrophobiA.net
i cant wait to see pics..i think your license plate said that you from hawaii......hwat island would that be...please post the pics of the fully bagged thing ASAP
1 - 20 of 115 Posts
