body dragger
here's the scoop... i have a viair 450 mounted underneath my bed, and last night as i was dragging, i noticed that my comp. wasn't on anymore. i got home, and nothing. so i thought it might be a bad pressure switch. took it off and ran a straight power wire, nothing. i heard when the 450's go, the still turn on atleast... i was thinkinh maybe a bad ground??? :bawl: :bawl:
Had the same problem with one of my 450's, it just quit working. Checked everything, finally hit the relay with a wrench and bam, started right up,,,,next day, was going down the road, both 450's was running, one kicked off and the other one decided to keep going...went back and hit the same relay and it kicked off, needless to say that relay is now replaced
