1 - 13 of 13 Posts
Nasty V8 S10
Nasty V8 S10
Discussion Starter · #2 ·
well i guess i should put some pics here for all those who dont want to go to the site........
Nasty V8 S10
heres a movie, dont know if it will work but o well
Nice truck, how about some specs on the engine and drive train, what do you figure you are putting out for power?? I bet you will have a blast with that truck I did with my 1st small block S-10 that is why I am building another one now.
Nasty V8 S10
have a 1991 fully restored 2wd 350 S-10
it took me over 2 years to do and i did it as my senior project for highschool. the truck has a pretty highly moded engine(around 400 hp)
Engine:
corvette L98 lower end (ballanced)
high volume oil pump and water pump
edelbrock 750 carb
edelbrock performer intake
built HEI distributor with high output coil and spark manager 8 MM wires accell shorty header plugs
hedman shorty conversion headers Jet Hot coated inside and out
ported 1.94/1.5 heads
cam: 270 degrees of duration at .050 lift (actual)
dual 2.5 inch exaust all the way back through two high flow cats and vortex mufflers (rated better than flowmaster)
griffen 5 core radiator (fits inside the radiator support!= more clearence for high flow steel race fan) She gets hot!
Rear:
****ty stock 7.5 inch open 3.73 :mad:
it also has a built th700r4 trany.
it now has 16x8 torque thrust II's on it.
all suspension has been changed to poly bushings, all poly body mounts. the truck was factory lowered 4/4 wich was done with 4 inch spindles (this is not available anywhere!) and 4 inch blocks.
the paint is 2001 mercadees silver. 3 coats paint, 3 coats clear.
i have some pics on my webpage http://firstclass.wit.edu/~zacche7207/
they arent the most recent cause it is all finished but there are movies of it completed on that site. as of now, my dad made a bet with some of his friends and now we have to make at least 725 hp inorder to win the bet, this means that a blower is going to be added, as well as tubbing out the rear! i'll send pics when i get that done! on the inside i have a custom dash panel that i made from some hand polished aluminum.
STEREO
kenwood excelon 817 head
boston 5.25 components in custom fiberglass kickpanels
10" jl W3 in custom box with amp rack
alpine v12 5 channel powering it all
4 gauge power
4channel porsilin monster cable rcas quad helix!
monster cable double helix speaker wire!
dynamatting allover!
really loud fronts are bridged 150 watts to each front and 150 to the sub but it is really clean!
Engine mods comming soon!
383 stroker kit
dart pro 1 aluminum heads
6-71 or 8-71 blower!
bigger cam for the blower!
Traction mods comming also!
tub out the rear
traction bars
transmission change?????
Ford 9 inch rear? or chevy 8.5 inch? POSI OF COURSE
4.11 gears
Sounds like a pretty wild ride and from what I saw from the video it is. Keep up the good work and win that bet. I will post some pics of my 355 when I get it done and installed in my truck.
Nasty V8 S10
Discussion Starter · #9 ·
Nasty V8 S10
Discussion Starter · #11 ·
thanks!
Nasty V8 S10
Discussion Starter · #13 ·
thanks!!!
1 - 13 of 13 Posts
