Goodness goodness...goooddddd NESS...
Wow, this 2001 4x4 dream truck I got from a county surplus auction is unraveling my feel good mojo.
Good points---
Starts easy...Runs quiet.
Worst problem first...
4x4 sounds like it engages (i hear it click like it is locking into the front transfer case--just like my big boy 2500hd does)...No 4x4 action--right rear spins easily...no pull from the front going up a grassy incline...No front spin.
Searched 4x4 problems and since it had a front end collision Ill chk the vacuum hoses behind the headlights...
ALSO--- I noticed that the dome light fuse is connected the 4x4 system.... So seeing how this was a Sherriff County Undr Covr drug vehicle, they disconnected ALL internal lights.. .dome light is missing...would that be enough to "short" the circuit??
2nd problem--
Huge bearing/brake rotor noise.... I'll look into that after fix #1...
3rd problem
A/C noise--- blows EXTREMELY cold air but has an awful grinding whirling noise that I can only guess is the compressor?
Again, any help with the 4x4 system would be great. Like I said, I pressed the buttons, and there was an audible MECHANICAL click like the transfer case was getting locked in...
Did I mention these County Fleet Yahoos put Blue Locktite on each and EVERY stud on each and EVERY wheel??? I started all jazzed about scoring a pretty decent 4x4 truck...
Good points---
2nd problem--
3rd problem
