Icy S-10
:bash: I SEEN IN SPORTRUCK MAGAZINE THAT THERE IS A CAM FROM COMP CAMS THAT GIVES 42HP AND IS SMOG LEGAL. HAS ANYBODY INSTALLED ONE OF THESE AND HOW HAPPY ARE YOU WITH IT?
Spoolin' Fool
Do you have a 4.3? If so what year? The reason is because in '92 they used a balanced shaft to dampen the harmonics in the engine and they used a different cam which is almost impossible to find an upgrade. From early '92 down they didn't use the shaft and cams are very accessible. As long as its an early engine a cam would be a nice upgrade. 43 horse might be a little exagerated but it will make a difference.
Comp makes 3 good grinds for...
4.3 with balance shaft and computer control. They are p/ns
56-440-8, [email protected] is 206/210, lobe seperation 112
56-450-8, [email protected] is 210/215, lobe seperation 112
56-460-8, [email protected] is 215/220, lobe seperation 114
first two have I/E lobe lift of .333/.333, last one has .333/.34
Comp will also do a custom grind for you at same cost.
Crane also has 3 but I perfer Comps tech service.
Spoolin' Fool
News to me. When I was looking to get a cam for my '92, I was having a hell of a time because everything I found was for a non-shaft motor. Are these cams higher priced? Isn't there an extra gear at the front of the cam to run the shaft?
