This problem started off as very light hesitation. It has now grown into a very big problem. When i now start the truck it seems to run on 3 cylinders until warmed up. After it is warmed up it randomly misfires. THere is no check engine light coming on. Checked the spark plugs, they are fine. I need to get this fixed as inexpensively as possible since i am trying to sell the truck. Thanks in advance for everyones help.
~Steve
thanks, will do, what does that usually run? how about replacing them what does that cost? i know aftermarket is a fortune.
I should have had a V8!
I've been having the same problem....replaced the coils and everything was fine for a week and now I'm trying to replace the ignition control module. But get this.....10 brand new modules, 2 different brands, 2 different stores---ALL FAIL THE TESTER STRAIGHT OUT OF THE BOX! Good luck!
im coming up with a good plan of action, get rid of it before i have anymore problems while it still runs great
