So, just got my mirrors in that I ordered from a place called K2 Motor, M3 style manual mirrors to get rid of those huge cattle truck stockers. Went to put'em in and got that sinking feeling. No instructions included but I'm a man so who needs em, right?
Yeah, guess I do. What I got is Mirror, bracket and screws. Looks like mirror mounts to bracket with said screws, and bracket bolts to door. Only problem is there are no mounting holes on inside of door. The application says its for 82-93, but I am semi-certain these will fit a second gen and are meant to mount from the inside. Any you fellas know what's up here or what I can do?
by the way, here's the link to what I got:
http://www.k2motor.com/rmms1082mn.html
Self Portrait
For my SS mirrors you had to drill three 3/4 holes on the inside of the door shell to access the welded-on bolts that the stock mirrirs bolt to. You drill out those bolts then run the new bolts through from the inside into the mirror on the outside.
