lately ive been going into town (7 miles most) and my mileage seems to have gone to ****. i burn about 1/4 tank to get there and back. so at most im going 20 miles. wtf is up? is it carb probs?
injector cleaner doesn't really work. if you keep running it then it works fine but that is after about 2-3 months of continued use
CHECK YOUR CAT
Is it blowin back thru the carb, won't accelerate, stinks of gas, could be back pressure from a plugged cat.
the only reason i wouldnt think its the cat is that it is brand new. i had to redo my whole exhaust system when i registered the truck 4 months ago. DAMN CALI SMOG LAWS!!! :mad: and it doesnt smell of gas any more that was taken care of. it was just a hole in the exhaust pipe where there was a crappy weld that broke. yet it does hesitate on acceleration, plus when cold it holds 1st gear longer than it does warm.
life begins @ 20 psi
Have you tried to pull the codes stored in your ECM by attaching a jumper between the ground (pin A) and diagnostic terminal (pin B) on your ALDL? You don't need to have a code reader to pull the codes but, it makes it easier. HTH
Mike
