Alright tommorow i am hopefully going to be getting my blower back, i am going to be running... ball park 6-9lbs of boost, I am installing Devils own meth injection with a #3 or #5 nossel.
First off, which nossel start with the #3? or 5? also what the difference.. if i install it with the 5 and it goes rich i can tune it out.. or is the idea to use a little meth as you can?
Now the one i'm kinda worried about, the usage.. how much meth/water are we talking, I am going to Mi to road race in like 3 weeks and will be on a track for 15-30 min runs straight and need to be able to go that long without needing more. I figure this takes the washer fluid tank out of the picture and probably puts me at mounting a 3-5 gallon plastic fuel tank in the bed and plumbing it up from their. Is their any reason i shouldn't do this? or will it not use enough to render a tank in the bed with a 3 or 5 nossel?
And last of all, whats your ratio, depending on who you talk to at devils own, one says 50 50 the other says nothing but 100 meth. I am leaning more toward 100 meth just because I would like that extra strain taken off of my TBI injection. However right now i'm not pushing the injectors that hard in the tune and really not pushing their max pressure only putting them up to about 18psi at max boost when i was running around 5lbs of boost.
Thanks !
Thanks !
