1 - 1 of 1 Posts
I measured it to find the offset and backspacing.
I'm assuming 1" = 25.4 mm
If the backspacing is from the mounting surface to the very back of the rim it is: 4.25"
The offset is the mounting surface to the centerline. The wheel is actually 9" wide including the outer lips. 8" inside the outer lips.
9/2 = 4.5 - 4.25 = .25 = 6.35 mm negative offset
8/2 = 4 - 3.75(.5" less from excluding lip) = .25 = 6.35 mm negative offset
I have never found any information on this anywhere in the entire world. I hope my calculations are right.
Now, I have ASA JS5's from tirerack.com. They came with .75" spacers and in a BMW bolt pattern (5 x 120) They fit fine and have had no problems for 2 years. So the spacers come out to be: 19.05 mm
So to place the rims the same as factory it would mean the offset of the rims is:
19.05 - 6.35 = 12.7 mm positive offset
So hypothetically I could use any rim with the same bolt pattern and same spacer if it had a 10 - 15 mm positive offset. Maybe even 20mm.
I hope this all makes sense. Let me know if anything is obviously wrong.
1 - 1 of 1 Posts
