Turbos and Naws
Does anyone use check valves to bleed boost away from the map sensor to prevent a ses light? the check valve bleeds boost so the map sensor sees 0 vac, and no boost.
Turbos and Naws
how would a diode work in there
There has been some documentation of a lean mode (protective fuel cutoff designed to protect the engine from prolonged high speed operation). It is triggered when the MAP pressure is above the protective set point for a programmed number of seconds. The protective trip causes the fuel injector pulse to be set to zero, shutting off fuel until the trip condition is cleared. One example would be the vehicle bucking or feel like it's missing when first getting into boost - and setting a code.
Here's how the diode gets around this. Basically, your MAP sensor reads a voltage between 0 and 5 volts. About .5v being idle and near 5v being WOT. Wiring in a Zener Diode effectively fools the computer by draining any excess voltage above it's set point (4.7v) to ground. This way the computer never sees boost and avoids problems it might have had in that situation.
Check out this page for wiring instructions. http://minimopar.knizefamily.net/perf/mapzener.html
This is on a turbo dodge car but uses the same principle.
Turbos and Naws
Good Call Thanks for the info.
