1 - 11 of 11 Posts
praise the lower'd
ok i want to put make an air tank that will fit between the spare tire and the rear bumper on my 99s10 so i measured it out and i could but a 6" tube by 34" long. soo i did the math and it came out to be 6.62 gallons???? is that right? im a little rusty on my math so could the MATHWIZZ help me out here?
thanks a lot
scott
i did the math like if i had some 6" tubing with 1/8" wall, even though that is more than overkill. tks again
stinkynathan said:
V = ð(r^2)h
sooo...
V = (3.14)(36)(34)
V = 3843.36 cubic inches
since 1 cubic inch is 0.004329 gallons
V = 3843.36(0.004329)
V = 16.63790544 gallons
Your math is off..He's talking 6" Diameter, not Radius... Therefore it would have a Radius of 3" so:
V = (3.14)(9)(34)
V = 960.84 cubic inches
V = 4.16 Gallons
Which sounds about right since Air Ride's new tanks are 7" in diameter and 34" long and they are 5 gallons. Also, please remember that these calculations are based on 6" being the INNER diameter, as opposed to the 6" OUTER diameter I'm sure you are referring to...
Also, when making your tank Altophobic remember to make the ends rounded and not just flat plate...There is a reason why all compressed air tanks are rounded and have no sharp edges...
I also recommend that you get your tank leak checked and pressure tested by a reliable testing facility. Just because you welded some steel together doesn't mean it will hold air properly.
1 - 11 of 11 Posts
